Running a 4ohm single voice coil sub at 2ohm?
Aryan
I am having a single voice coil 4ohm sub with 325w rms I am looking to buy a mono amplifier as i want to make full use of the rms. Also looking to buy another similar single voice coil 4 ohm sub with 300w rms(not 325w rms as earlier because it’s unavailable)
Ques1 Is it safe to run two 4ohm subs at 2ohm, assuming i wire two 4ohms single coil subs in parallel?
Ques 2 since both the subs are similar but not exactly same one is having a little less rms at around 25 w rms less than the other one will it be compatible for parallel connection? Both are 12 inches jbl subs
The mono amps i am looking at have a rating as
300w rms* 1 at 4 ohms
500w rms* 1 at 2 ohms
800w rms* 1 at 1 ohms
You will be fine running both at a final 2 ohm load as long as the amplifier is stable at that ohm load.The 25 RMS wattage isnt that critical between the subs to hear any if much of a difference. Tune both properly and you shoulld be just fine. Id look at an amplifier that puts out approx 600-1k rms @2ohms to get the most out of the subs. Examples to follow below
Even the 1500 would be nice
Ive put a few of this brand in and they are and have been doing quite well for quite a while.
Here is your wiring Diagram for a final 2 ohm load on the subs. Pretty straight forward
Great advice sir, i ll have to check if those amps are available in india though
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
I would not recommend mounting it upside down. Not good for amplifiers. it will more than likely get too dammned hot and fail. you can mount...
Aryan
Aryan
Buck
    May 10, 2024
3toneEYZ
    May 10, 2024
