Hyundai Sonata 2016 $1500 setup
lamarkus m
I’m trying to get a sound system into my hyundai sonata 2016. I’ve had sub systems in the past in previous vehicles. But this one I want to do better. I have a budget of 1500. I was thinking 2 american bass XFL 12s with either a taramps smart 3 or a JP23. I was going to just go shae prefab box. Do any one have any suggestions? I just want a legit setup that can last and is a good bang for my buck. Thanks!
You'll need to spend some money on electrical updates. I have a 2013 sonata and get some pretty bad light dimming running about 1500 watts. If I wasn't planning on selling this soon, I'd be adding an extra battery or bigger alt.
I’ve never dealt with upgrading electrical.. any suggestions on an extra battery ?
I don't know too much about them myself as I won't be doing it till I get my next vehicle, so haven't done too much research. For cheaper options I see a lot of guys go with an agm. I'm planning on lithium. Smaller and lighter, but more expensive. I saw someone talking about "glow" something lately. Can't remember the name, but maybe @Doxquzme me can chime inSeems like a good price for what you get.
Edit: the lithium is called glow voltage.
The 2013 comes with a stock 110a alt. Not sure what the 2016 has. I'm running a crossfire vr1000d for the sub and a taramps 100x4( can't remember the model) bridged. Gains set at 150x2.
I’m trying to get a sound system into my hyundai sonata 2016. I’ve had sub systems in the past in previous vehicles. But this one I want to do better. I have a budget of 1500. I was thinking 2 american bass XFL 12s with either a taramps smart 3 or a JP23. I was going to just go shae prefab box. Do any one have any suggestions? I just want a legit setup that can last and is a good bang for my buck. Thanks!a
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst. Before dropping $500 on getting an HO alt and the corresponding electrical upgrades, this would be a viable option indeed.
Or this Mini version
If you have the room, I got that guys big brother, this one, BNIB $225 shipped!
Or one of these
Big AGM under the hood and a LiFePO4 in the back, parallel rund and grounds, all you will need. Cost less than an HO alt, less work to upgrade and better performance overall.
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
259
674
lamarkus m
lamarkus m
Springfield MO
    May 8, 2024
    May 8, 2024
