Stinger out with 4 and 5 channel versions of their monoblocks
Interesting. They look pretty nice and affordable. Though Im not sure I like the speaker connections, but Im sure they could be overlooked verses performance.
Too bad the 5 only does 300w @ 4 ohm...I could've moved my 6 channel out of the saturn to the Deltasaurus 😂
Guess it gives me an excuse to buy the delta a new amp🤣🤣🤣
Pros and cons, they are pretty easy actually but require a bit of patience for sure. Used to hate spades/rings but that is because I'm lazy (solder/heat shrink). These are pretty small, maybe 16 gauge max.
5 CH specs from Stinger site.
Model Number MT-1000.5
Channels 5/4/3
Continuous Power (RMS)
(<1% THD @ 14.4V) 150W x 4 + 500W x 1 @ 2Ω
75W x 4 + 300W x 1 @ 4Ω
300W x 2 @ 4Ω
700W x 1 @ 1Ω - CH5
S/N Ratio @CEA Standard -90dB
Input Sensitivity 0.5v-11v
Gain 0.5v-11v
Frequency Response 10Hz - 180KHz
Bass-Boost Frequency Range CH5: 10Hz-180Hz
CH1-4:10Hz-20KHz
Bass-Boost Q 0-12db
Efficiency (Average) 80%
Topology Class Class D
Crossover xover Multiplier X1: 50Hz-500Hz
X10: 500Hz-5KHz
40Hz-180Hz - CH5
Remote Level Control Included
Operating Voltage 9V to 16V
Power Terminal 4 Gauge
Speaker Terminal CH1-CH4:12AWG
CH5:8 Guage
Recommended External Fusing 150A
Dimensions 13.23in/336mm L
2.09in/53mm W
6.10in/155mm H
You need an excuse?
Sorta 😂
I kinda wanted to move my symphony s6 to the delta and grab a 5 channel for the saturn (I'm leaving the components, rear coaxials in it) and I need 600ish watts @ 4 ohm to run the dayton 10" that's a front sub now as a main sub. The s6 does 700w the 5&6 bridged.
On the upside if I grab an 8 channel (most likely that trinity audio 8 channel) for the delta instead...I'd "only" need 3 amps for that build 🤣
Sorta 😂
This guy offered me $332.45 on ebay for a BNIB Trinity Audio 8 channel. He's only got 19, better hurry!
There is your excuse! :D
I'm gonna grab one off Amazon when the time comes...just in case there's an issue 😂
At this point I'm waiting to get the delta up to the shop to get an idea what can go where before I grab too much gear for it
It's a good thing they do good work without overcharging...this thing is gonna be beyond my stone age abilities 🤣🤣🤣
You can always go Old School and find a decent 4 ch and go Mix/Mono in the Saturn?
I could on the cheap since I got a couple 4 channels kicking around 😂 but then I'd need 4 amps in the delta. No matter how do it I'll need 10-11 channels (depending on if i can shoehorn a dd VO-M10 under each seat or just one under/in the glovebox) all together in that big sob 🤣
I'll be doing 3way upfront, 6x9's on the rear deck that's an 8 channel right there 🤣 plus an a 3k mono for the subs and either a small mono or 2 channel for dd VO-M10...even though I got a huge trunk 3 amps, a pair of 15's, a minidsp 8x12, rear battery is gonna eat some space 😢
I seriously considered going with a 3-way rear fill, just so I had a reason to get that 8 channel trinity amp! I finally came to my senses!
That'd be cool as hell to look at but it might make ya bald trying to eq it all 😂
I'm just gonna do coaxials on the rear deck in small boxes 😳
Worst case scenario is that trinity is a turd and I buy 2 more symphony s6's 🤣
It's kind of could all the new multipowered amps coming out. makes staggering active stages a reality. With the use of GaN fets coming along, going to see some ridiculous high power small 12+ channel amplifiers. Hybrid full bridge/half bridge combination, truly all in one amplifiers that also have DSP. Should be interesting to say the least!
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
I was going to check that Vid out the other day when it popped up, and I still, havent watched it yet..LOL. Let me check it out.. Thanks
My zapco DSP has optical input as an option My question is does anyone know or have firsthand experience if the optical output on the Joying, or...
Premium Member
Current build, 2012 Mazda 3 Hatch 2.5T
Boise, ID
spokey9
    May 12, 2024
    May 11, 2024
