01 S 10's WALL BUILD, 2 15"s / 4kw
looks pimp
get er sealed up and get some numbers now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
will do, hopefully it will be done next week, but i need some extra money so i might have to wait until my paycheck friday to continue.
Im guessing 149.2 legal on the dash, but i want to break 150. This is a daily/music wall, 38hz, so i dont care as much about the numbers.
nice build.....did you know they make extended cab pickups just to give you enough room for a good system
yep, too bad its not a crew cab //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
some more pics, just got done with the bracing on the inside, and sealing up the seams. the glue and everything makes it look nasty, but i might line the inside with truck bedliner also
test fit, im gonna get another sheet of mdf tomorrow and start the second baffle. it will be the final baffle that will fit snug against the cab, the sides and the roof on the inside.
im waiting on one of my Batcap 2000's to get here tomorrow, its gonna go on the right hand side of the box where that 2/0 welding cable is. I will buy another this friday when i get paid, making a total of 3. 1 upfront with my redtop and two back there //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
got the wall in for now, just the first baffle as of now. I have the cardboard on there to get the rough fitment for the second baffle, im gonna flush as close as i can to the sides and roof of the cab.
I'll just transfer the cardboard to another sheet of MDF and cut out the second baffle. The subs will be flush mounted also. both batcap 2000's are on the passenger side of the box where the jumpseat used to be. i might get a third for under the hood again if i have the cash
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
917
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
01 S 10
LOUD
01 S 10
Central Florida
01 S 10
