02 Altima wiring issues
  • 3
jbake2166
So I have a 2002 Nissan Altima sl, which includes the stock bose system. I'm fairly new with car audio, but I've read up and researched a good deal. I just have absolutely no idea what to do to get everything to work. Everything other than the input wires to my new amp is set up and ready to go. I just can't figure out how to supply the audio signal to the new amp. Basically, I have tried splitting the input wires going into the clips for the stock bose amp for my rear speakers and connecting them to rca cables to plug into my new amplifier I'm going to install. (I did the same with the remote turn on) However, this resulted in my radio turning on, yet absolutely no sound came from ANY speaker in the vehicle. Now I have tried buying a OEM adapter that was supposed to be able to allow you to add an amplifier to 1995-2002 nissan vehicles, yet that does not fit with the wires in my trunk... I have no idea what else to try to get this installed and would prefer to save my money by not going to a shop. Any ideas? Anyone have this problem with their altima before? Thank you for any help!
i dont mess with stock radio. but i believe (believe) on your amp theres some wires called high input i believe you connect the wires from the radio speakers to the amps high input wire and bam it should work. anybody here agrees or desagree...
Not less power but less channels. Maybe upgraded all around Bose speakers as well.
9
The harnesses showing up for your vehicle show one or two adapter plugs. If your car has a separate CD player, then I assume that is what the 3rd...
so, here is what im working with and end goal and working with 100% factory Car 2009 nissan altima 4 door base radio Music style Country rap...
The Sakr OFC wire is as good as any other for that price for sure, not talking about their amplifiers. If you have enough, dual 12 gauge runs are...
6
68
I have 8 Rockville W8K6D4 V2 dvc 4ohm 1400 peak 350 rms 8” subs. I’m gonna wire them to a Taramps bass 3k 1 ohm 1 channel amp. I’d like to wire...
5
136
jbake2166
jbake2166
Cleveland, OH
05trailblazer
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
