06 BMW 325ci build
  • 1
E46_droptop06
CarAudio.com Newbie
Figured I’d go ahead and start now that I almost have all the components to my build. Few odds and ends to but still but close to starting fab and install.
Will be running
2 Resilient Sound Gold 10s wired at 2 ohm each in a ported box at 35hz
Powered by 2 Sundown SAEv3 2500
Alpine R-S65C.2 & 30MC midrange upfront
Alpine R-S65.2 coax rear fill
Diamond Audio Micro88u
Amps will be mounted in a false floor and
covered with plexi and fans in push/pull configuration
Audio Control Matrix Plus Line Driver
Electrical
270A PowerBastards Alt
H8 AGM probably either XS or Odyssey
Ioxus UC31 Ultra Cap
Wiring will be all Knukonceptz. Still unsure about distribution and terminals.
I’ll be sure to post pics and videos of the process and finished product.
Box design 3.1 cuft tuned to 35hz
6.5” Alpine type R coax in the rear. Going to find a black tweeter grill to match later on.
Front doors are done. 6.5”s & the 3” midrange are in the stock location behind the grill next to the door handle. Up next tweeters in the pillars hopefully tomorrow or Thursday.
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
7
953
I have a pair of IS BMW 100L on order. The next upgrade will be the center and/or the amplifier. The Focal center is much cheaper, however many...
11
Sounds like you already have a plan. Hook it up and let us know how it worked. Good luck.
E46_droptop06
CarAudio.com Newbie
E46_droptop06
North Carolina
E46_droptop06
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
