1/0 ring terminals
I may end up using the Knu oversized CCA. Or something similar if I can find some soon.
If you look at copper terminals then you will want 2/0 more then likely. The wire will fit much better and it will be far easier to crimp or solder as you won't need to trim the wire down or anything.
The lugs I posted a pic of on here are 2/0 on "1/0" wire.
x2 on getting 2/0 if you go with welding lugs.
VTE Warehouse used to have the hookup. 100 2/0 shipped for $28 but they've been out of stock for a while...
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
751
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Beatin'
Beatin'
MI
parasite
maylar
    Jun 2, 2024
    Jun 1, 2024
