1 of a kind Skar Audio VVX 10s
g6ryder
2x Skar Audio VVX motors, with SPLaudio soft parts. These are 2 of 2 only ones like it from my knowledge they are the only custom reconed VVXs around (dont quote me). Put up a 143.05 at 33htz in a trunk on a SK-1500.1D
Great condition maybe 2 hours of play time since recones. Excess glue under the gaskets (you dont ever see). Gasket have some shreds in them due to the Sk-1500.1. Corey owner of SPL audio said they should double in rated power easy so lets say 1200rms a piece. These have much better soft parts all around 6" Dome dustcap high roll surround beast 2.5" coil been told by corey it has more copper than the Zv2. D2 coils
215 shipped EA Will come in original boxes
ONLY TRADES WOULD BE 50ft 1/0ga and xs power batts.
FedEx
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
11
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
492
11
889
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
g6ryder
g6ryder
Claremore, OK
Kangaroux
