10" Kicker Comp VX 10 vs ARC Audio 10D2 winner is....
  • 1
brianashadow
I have a 2011 Jeep Cherokee and I am currently running a Sundown D1000 amp. I was wondering which of the above mentioned subs would be better. I plan at running it at 1ohm and getting about 900watts to the sub. It will be in a ported box, and I listen to all types of music. I'm looking for maximum amount of bass with a balance of SQ. Any other sub suggestions, with reasoning also, would be greatly appreciated. Thanks.
BA
Question…Will a kicker solo x 15 in a custom 5 cu ft enclosure hit in a ford edge with a kxa1800/1? I also have a UC31 with an AGM battery.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
530
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
brianashadow
brianashadow
Florida
brianashadow
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
