1000 watt+ rms 12" sub?
  • 2
aberant1
Any recommendations on a 12 @ 2 ohms with over 1000 watts rms and under $300?
Has anyone heard the new ORION XTRPRO124D?
Or the Lanzar OPTI1234D?
I'm looking for something for a daily driver, had an NVX VCW on a 1000 watt jbl amp but the amp was way too much for it to handle with the gain barely up to 15%..
american bass XFL 12, soundqubed HDS312, SSA Icon, Incriminator audio flatlyne, FI SSD
Just to let you know, even at 15% gain, you can clip without knowing it. Many different variables can drive your amp to clipping. EX: pre-amp output voltage is too high, dirty bass from music recording, your car's electrical voltage dropping too low. Playing too low below box tuning while pushing it hard can kill the sub too.
I looked at the XFL and HDS312, I'll have to check the other ones out. I did have the amp professionally installed and gains set but your right I could have other issues. I listen to bass heavy music with a lot off rolling bass lines that get pretty low. The amp doesn't have a subsonic filter but I really wasn't pushing it that hard, just breaking it in and the sub didn't last for 15 minutes before it started falling apart. Thanks for the reply!
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
777
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
aberant1
aberant1
fort wayne, IN
aberant1
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
