1000 watts or so @1ohm
MANTI5
4
Southern AZ
Looking for an efficient amp that will do a CLEAN 1000 watts @ 1ohm, is under $150(more so the better), and small enough to fit under a civic front seat if possible. The last part isn't a deal breaker, just a preference.
Best offer so far, will let you know soon. I'm just waiting on a payment from a sale.
Ok, I sent you another PM with some more info. If you need anything else, let me know as I still have some more stuff around here.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
795
MANTI5
MANTI5
Southern AZ
Ignatowski
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
