1000 wrms at 2 ohm need help
pyrothug434
chicago
looking for an amp to do around 1k rms on a not so perfect electrical and so far the only amp that i can really think of even buying is the ed nine.1 because its on sale right now for 195 new but was wandering if anybody else thought a different amp could do better at around the same price range
ur about a wk late.. was going to sell my zx1000.1 but ended up buying 2 IDQ15s to hook up to it
yes i looked at most of these amps but they are all tested at 14.4 volts i have a not so great electrical in my car right now so just trying to do something on low volts as i was saying ed nine.1 rated 900 at 2ohm at 12.5 v
only does 750 at 2 ohm from specs an even with mayb like 13 volts and if it was underrated it would probably only push around 900 to 1k idk tho
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
806
pyrothug434
pyrothug434
chicago
pyrothug434
Decebal
    Jun 10, 2024
