12'' Adire Brahma MK II
boomzabit
Minnesota
12 inch Adire Audio Brahma MKII
Cosmetically Id rate it about a 7 out of 10. I keep most of my items prestine, but the gentleman I bought this speaker from did not. It has your typical scuffs and light stratches. Performance id have to say its a 10 out of 10. Sounds great, very musical and can get rather loud for daily driving. I had this in roughly a 2.0 cubic foot ported box tuned to 32-33 hz. If your wanting SQ, this is an impressive setup. Anton Miller formally from TML (Team Minnesota's loudest) built the box for me, and Chris Russ (founder of TML) gave me a hand doing the install. If I remember right, RMS on these were 1600w and 2400 peak.
Ill go $300 shipped on this.
Id love to hang on to this peice, but its winter time and I have other projects that need attention. I may be getting out of the audio side of things for while so I wont be able to take any trades. Sorry folks. These are the only pictures I can find on my PC right now, I will have more detailed pictures this afternoon.
eff the pdf,.. ppl are scared of links
Brahma Power Handling 1
There's a common misconception that a power rating is a power requirement; in fact, the two are completely different things! Brahma is rated at 1600W RMS per IEC268-5 (a specific test signal). Does this mean you need 1600W to get full performance from your Brahma? NO! What it means that your Brahma can handle 1600W of power with the test signal (akin to typical musical spectral content).
Below are some tables that show what amount of power is required to push a Brahma (10", 12", or 15") to full excursion in a sealed box. The tables break down a typical box alignment and show you the amount of power you need to reach full excursion below 30 Hz:
Brahma 10
Qtc-Size (liters)-Size (ft3)-Power Handling
0.5-24.7-0.87-700W
0.577-14-0.49-1000W
0.707-7.5-0.27-2000W
0.8-5.4-0.19-3000W
0.9-4.0-0.14-5000W
1.0-3.1-0.11-7000W
Brahma 12
0.5-170.5-6.01-400W
0.577-59.8-2.10-500W
0.707-25.9-0.92-900W
0.8-17.6-0.62-1300W
0.9-12.6-0.45-2000W
1.0-9.6-0.34-2800W
Brahma 15
0.5-862.7-30.48-400W
0.577-204.5-7.26-500W
0.707-80.6-2.85-800W
0.8-53.4-1.89-1200W
0.9-37.9-1.34-1800W
1.0-28.6-1.01-2500W
italicized numbers are above thermal ratings and are NOT recommended!
One thing to note is that in most cases, you need less than 1000W of power to push a Brahma to its limits. Going beyond the power listed won't gain you more SPL - what it will do is simply slam the suspension,and cook the driver (because cooling relies heavily on cone motion, if power is increased and cone motion is not there can be cooling reduction). So, if you're looking to power a Brahma, take a look at the above sealed box sizes, and choose amplification accordingly!
Can you push up on cone so we can see the coil?Clearly you have been putting rated power on the coil and that's not what the sub suspension can handle.
hey brudder,.. knew it was only a matter of time before you showed up, lol
not a clone...they use the same motor.....these things are just as good as the XXX
Negative, negative and negative. The brahma extreme used the same motor as the xxx..later the tumult. The Brahma used a similar motor to the HC.
They were rated at 1600...
I should be able to get a picture or two of the VC's tomorrow. I had my mine on a kx 1200.1, I never once smelt VC's nor did it ever sound like it was bottoming out. I also forgot to add. I did a 142.8 on music, during a midwest SPL show. I wasnt going to participate but figured id see what I can do. Anyone can call me out, but I do remember Adire rated these things at 1600w. I was going back and forth between this and the XXX and went with the XXX. Clearly I must have made the better choice. Maybe thats why Adire went under? For over rating their woofers. If I can achieve the same SPL with a smaller amp I may just hang on to this subwoofer.
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
boomzabit
boomzabit
Minnesota
perfecxionX
Decebal
    Jun 10, 2024
