12" Fi SSD box
  • 3
Sketchup
Iowa
I made this quick box in google sketchup, This is the general idea that I have. What else would I have to do or modify it to make it 33Hz or calculate the Hz. Also below are the specs for the sub. I would calculate the area of the box, but I have to go to bed soon. Even then I don't even now if it would be tuned to the correct Hz. Any help please comment, first time ever designing a box, I put dimmensions there, please correct me or tell me what I am missing or should do.
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.500”
Displacement: 0.14cuft
*Please tell me if the pictures aren't working for you...
You're not taking the port and sub displacement into consideration when finding the needed port length for the given volume that you're wanting. The box is just 2.07ft^3 before sub and port displacement. The port displacement is going to be 12.5" x 2.75" x ~19" long, so you're looking at ~.35ft^3 there, on top of the ~.1ft^3 for the sub displacement. That'll put you right around 1.6ft^3 after displacements, and a 1.6ft^3 box with the port you have drawn in there gives you a tuning of ~43hz. If you want the box to be 2ft^3 tuned to whatever hz, then you need to account for all other displacements so that after them you have the final 2ft^3 that you used to find the port length.
Glad they stepped up and replaced it! I honestly would have thought it was super petty if they didn’t just swap it out for you still being under...
6
Buck has been my go to since I got into builds, currently he’s unavailable and hopefully back at his passion soon (for privacy I’ll leave it at...
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
195
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
540
Sketchup
Sketchup
Iowa
Buck
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
