+125.4 ch amp
I have a brand new trifecta amp it has the same xenon board as a Sundown SAX100.4 for $160 shipped ..rated 12.6v 100x4 @ 4 ohm and 160x4 @ 2 ohm ...it has a built in full active crossover and designed to be run active ...
I'll pass, tyvm. Min I want is 125x4.
I’ll see if I have anything else... that amp will do 125+ on running car voltage 14.1+ ..the 12.6 is resting battery voltage most cheaper amps are rated and tested on 14.4-14.7 to get their peak power not real power
What Model#, I can't find anything on it. Just in case I have a change of heart or someone else is interested.
It’s an xtp 4 Trifecta 4200 when I google searched it it said it was 200x4 but I think that’s the 14v 2 ohm rating ..I paid over $200 when I bought it a couple of years ago for an ATV project but ended up going another route and never used it
Thanks. I will pass on this amp, just wanted to do a little reading on it.
Set the voltage to 20 volts via DMM and it will equal out to around 100 watts. https://www.the12volt.com/ohm/ohms-law-calculators.asp#voltage
140
333
463
West1
West1
Los Angeles,Ca
Ispector
