147 db on a LOW tuned box
Joe562MMA
so im getting 147 on music with a 14 foot cubic foot box for four 15 inch alpine type Rs at .5 ohm on one sundown saz 2500d..
im looking for suggestions as to what new box to build or should i just wall off my van i have an astro van..
i have 235 h/o alt/ one yellow top in front 2 ups 370fr in back an welding wire 2/0 running through t system
the next box is gonna be tuned higher i was just looking for suggestions an projections db wise..
im also thinking about getting a sound stream xxx 6500d to run my subs at 2 ohms an get supposedly 3298 watts at 2 ohms
how low is it tuned?
seems like the sundown amp would be the better choice-are you having issuses at .5?-why are you looking to replace it?
That soundstream amp at 2 ohms will not be an upgrade for you. Pics of this box?
officially 29hz
an the guy b4 me that had the subs on a hifonics 3000 hit the 147 i was just stating his term lab score being as to see how i have the sundown i figured it made higher rated power
449
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
620
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Joe562MMA
Joe562MMA
Los Angeles , CA
wenn_du_weinst
    May 20, 2024
    May 20, 2024
