15 in ch L7 needs an amp
charlieferrara
i have a 15 inch L7 Soloberic brand new (basicly) and i need a new amp for it because it blew a power acoustik 1440. Any sugestions for an amp that i can get 1000RMS out of? I want to get an amp that can move this power hungrey monster to it full potential please help:)
Polecat- i know you definatly know alot more then i do. but i think i need more power.
This is the amp you sent me a link to:
RMS Power Output: 600W x 1 @ 2 Ohm
Peak Power Output: 1200W x 1 @ 2 Ohm
Birdged Output: 1200W x 1 @ 1 Ohm
FOr the L7 15 inch dont i want 1000W for the RMS Power @ 2 ohm???//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
this should do it, $189 with 1 Year Warranty, should kill your sub if its 2 ohms
yea, it'd kill it with clipping and distortion...Boss???//content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
205
charlieferrara
charlieferrara
Orlando
charlieferrara
