15000rms Sonoma
Dub7sonoma
Premium Member
Premium Member
Trying to finish this ASAP. This will be the biggest build I have ever done. Still waiting on some things to hit the market and more money. Will update with more pics as often as I can.
Build Log:
2- Powerbass XTA5000d's strapped at 1 ohm
4- CT Sounds Meso 12s
2- CT Sounds 125.4
2- CT Sounds 60.4
4- CT Sounds PA 6.5s
2- CT Sounds PA 8s
2- CT Sounds PA Super Tweeters
Lots of Sky High 1/0
4- Deka Group 31 batteries (will be adding more)
2- Alternators
Lots of Ct Sounds/Audio Technix's deadner
Oh yeah I forgot to expain why im redoing it. Me and my wife had our first child a couple months ago and my original box for the DD 10s took up pretty much the whole rear cab of the truck. So I made some custom brackets and installed rear seats which came out way better than I expected. I figured since I was going to have to redo most of the install anyways...why not go way bigger. The new box will be a blow through with a sleeper camper shell
Looks good man!
And don't blame it on your son... you're rebuilding because that's what bassheads do. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
The other mids will be there by the time you're off work...
Looks good man!
Thanks. And as long as Ellie thinks its all for Jake (which it partially is) she's happy to see it getting redone
pics of the subs?
Don't you think that is a little too much power for them? lol
Don't have them yet. CT Sounds hasn't released them. They are rated at 2000rms each and if they are anything like the CT Sounds products I have seen so far, then they should take a good bit more. I figure ill be seeing around 6k, maybe a little more, from each amp. So 12000rms amp output on 8000(underrated) worth of subs should be fine. At least for short runs
Dub7sonoma
Premium Member
Premium Member
Dub7sonoma
Greenwood, La
Dub7sonoma
