150db trunk setup
156.1 db trunk setup. on just 1 18
trunk 1001+? peaking looks at aroudn 55-56 hz? must be a a$$ ton of power with how quick hes hitting that roll. but cool. sitting ont he wrong side too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
it would have been trunk 1000+ yes. 4 crossfire 1700s at .5 each on a level 5 18. sitting on the driver side to hold the engine rev.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
793
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
casey_anthony
casey_anthony
United States
bumpinexploder
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
