160 db with Kicker
Those jeeps get loud pretty easy.. The guy has two twisted 8.5ks... And it's a burp box Forsure... Those jeeps like something like 54hz or something. Sundown has video on there jeep like that doing stupid numbers with a single OA 15" and single Sa 18 and stuff. Still sweet to see on kickers and that is impressively loud still
Its 6 12s. 2 face forward. That thing was at finals out here. Ya its kicker blah blah....but 161 is 161. Spl isnt linear. Going from 148 to 151 is much easier than 158 to 161.
Those aren't normal l7 subs. I know this because the owner of the jeep is a good friend and I do shows at the shop he works at But that system is gone.
Just curious if anyone has ever put the 160 mill sundown deadner over some 80 mill cld .I'm talking about the kind you have to use a torch on...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
526
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
adulbrich
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
