16volt alternator question
  • 5
i have a xs power vcm and was wondering if i could use that and my high output 12v alternator to run a 16v system by setting the voltage on the vcm higher
Stock electrical will not sustain a 16v charge. You plan on running 14v batts to?
I think in order to do a full 16 volt system you would have to have a step down module in order to still run the tings in the car that still used 12 volts.
u can do it with a kinetic 3 post battery run the 12v post to ur car and the 16 v to ur stereo but be careful in my case the only thing that likes the 16+ volts is my bass amps the head unit and the eq will shut off if they get over 15.4 or so i have alot of experience with this type of setup on my tahoe i have 3 alternators 1 stock for the truck and the head unit and eq and 2 200amp running at 17.5 volts that go to the amps u can pm me if u would like to call me and chat about it
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
csu87
csu87
C Springs, CO
audiolife
