18 " incrimnator audio dp's
  • 3
cal
18 " incriminator audio dps tripple slug motor
dual 2ohm
both are used coils read fine and are nice color, both of these appear to have had recones by previous owner . one has some sort of drips on the cone / surround never had an issue works just fine , the other the gasket was stuck to the surround and when i pulled apart it rippped the outer skin of the foam did not go all the way threw i put some goop on it . i think somebody did a recone and put the gaskets before the glue fully cured and then had to cut the gasket off and on the one sub gave up. please take a look @ pics im listing these for what i was quoted on used motors. the only reason im selling is i bought 2 dc level 5 .
400 plus actual shipping for both
to get an idea these will cost average 55 each to ship. feel free to Get ur own quote i will not jack up or add fees.
shipping will be in a 20x 20 x16 and roughly 70 lbs each . will only shipp insured, 200 and ships from addison IL 60101
if ayone has a trade 1, 7k amp or 2, 3.5 strappable amps plus cash on my end...
A Link would be very helpful. Id be interested in taking a look at some gear
169
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
280
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
cal
cal
cal
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
