1990 c2500 voltage drop
  • 3
Dodge/Chevyman
I need help with my 1990 Chevy C2500 350 5.7l v8 i have had it for about 3 months now and before i got ahold of this truck the previous owner was having problems with it just as much as i am now, 1. If i get into the throttle to hard it will fall on its face, i have changed the distributor cap, rotor, speak plugs and wires it has helped a little bit but still acts up, 2. i just put a 10 in sub powers by a 600w fosgate with a jensen VX4012 when the bass drops really good the voltage drops i tested the voltage at the battery, alternator and right at the sub, there is not drop at the battery or alternator but at the amp it will drop as low as 11v, 3. when i use my lights at night or turn signals i get a drop and my truck has a hard time staying running at night with the lights on. What can i do to prevent this big voltage drop.
Check egr, mine was doing that and i cleaned it out and problem solved. As for the voltGe these trucks factory electrical is horrible the alt charges at 13.4. You need to upgrade the wires and do big 3 atleast.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
454
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Dodge/Chevyman
Dodge/Chevyman
Quincy, IL
frogcase2002
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
