1996 Dodge Ram sound system upgrade.
  • 2
Asablan671
CarAudio.com Newbie
I tried installing aftermarket 6x9s in the doors and there was a plug that had 4 wires in it red green grey black I believe I was told to cut the plug of the speaker and the red and green are positive and grey and black negative. I cut and spliced the wires pos to pos negative to negative and put the wires on the after market speaker plugged it in to the wire harness in the door on both sides turned key on and nothing. Did I do something wrong? Was I told wrong? Please help thanks in advance
They sell plug adapters for these sorts of things for only a few bucks on crutchfield. Might want to just buy those and see if you can figure out from there and hope you didn't break your head unit trying to hook this up wrong.
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
971
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
3K
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Asablan671
CarAudio.com Newbie
Asablan671
Washington state
hispls
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
