1996 Ford Explorer Build:
  • 3
disturbed471985
Start of build: Build is listed in sig doors are dead and big3 is done. Running 2 runs of 2awg later today and installing back 2 batts which will put me at 250ah worth of batt. Slow build but FS should be all done by next Saturday. Start of doors 2 6.5's and 1 tweet per door.
Tuned in! This sounds like it will be a good one //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
Ended up running both runs of 2/0awg threw frame as to keep the interior floor somewhat clean. 50ft of 2/0awg is now installed which is all that matters will grab a few pics of engine bay and rear batts once sun comes up...
off to a good start.. what made you go with the skars?
$60 a pop to my door and power handling really and overall good build quality. Heard a few setups using them and was impressed with the SQ of them and loudness.. Was going to go with DD vo's but heard a setup and price just made me say naw lol....
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
826
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
disturbed471985
disturbed471985
Greenwood, La
Papermaker85
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
