19mm MDF or 12mm marine plywood for sub box?
  • 2
Drifter mike
CarAudio.com Recruit
32
Greece
Hello guys,
I had on mind making a 250 watt RMS subwoofer ported box from 19mm MDF but recently i found in my house some 12mm marine plywood. So i say to use the plywood for my sub box as i will save about 20-30 euros and also the box is not gona be as heavy as the MDF box. What do you say? Actually what's the best option for the best sound quality between those 2 types of wood?
Hello guys,
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some of it looked like chipboard (kind of like fine osb).
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
9
3K
Drifter mike
Drifter mike
Greece
1aespinoza
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
