1ohm and 2ohm model?
  • 2
It means one is stable and produces the most power at 1 ohm and the other is stable to 2 ohm and produces the most power at 2 ohms. Do NOT wire an HD3000 to .5 ohm or a 2 ohm version under 2 ohms.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
Shipped from Amazon so its legit. Used it once before for something else and no issues.
12
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
486
Cuznfkr
CarAudio.com Newbie
Cuznfkr
Texas
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
