2 10"s in separate enclosures?
  • 1
If you can have different things on the two original screens I’d want to believe a compatible hu having the features you want may be attainable...
4
818
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
Yeah. Same thing here. The under seat box I did for the 8s was 325$. He’d already wasted that much with 2 prefabs that sounded like ass.
6
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
EnemyxXxGhost
Jacksonville, FL
EnemyxXxGhost
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
