2 10's sealed box, recommend highest overpower?
  • 5
NotSoNicely
USA wy
Hello, thank you for reading. Im a noob, i have a aftermarket head unit in a vw beetle. However i have 2 10" mtx audio subs. And a 600 watt amp. Im not sure what there rated for, but i found on there website they could be rated up to 250rms, so would 100watts over between 2 subs be to much? Thank you!
As long as everything is set properly you should be fine ..keep a clean signal with no clipping
you can throw a 10,000 watt amp onto them and run it no problem. Just because the amp does a lot of watts doesnt mean you have to use all of it. you can literally set the amp to do X amount of wattage if you have too much.
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
7
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
NotSoNicely
NotSoNicely
USA wy
Louisiana_CRX
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
