2 (2 Channel + 4 Channel) amps or single 4 channal amp?
  • 3
Thirdmainroad
India
Hello,
I have a Pioneer AVH X2790bt head, and a Pioneer 1200 Watt Sub. I also have a Sony XM N 502 amp (2 Channel). With these I have 4 low end Boston acoustic speakers.
I've upgraded my speakers to Polk DB 6501 for the fronts, and Polk DB501 for rears, as I can fit only 5.25 inch speakers in the rear. I have also bought a Sony XM N 1004 (4 Channel amp)
The config of the 4 channel amp are:
1,000 W high power output
70 W x 4 (4 ohms), 85 W x 4 (2 ohms), 175 W x 2 (BTL)
CHANNEL CONFIGURATION
4ch;3ch;2ch
MAX. CHANNEL POWER CONFIGURATION AT 4 OHM
4 x 170 W
MAX. CHANNEL CONFIGURATION AT 4 OHM BTL
2 x 500 W
MAX. CHANNEL POWER CONFIGURATION AT 2 OHM
4 x 250 W
FREQUENCY RESPONSE
5–50 kHz
To get the best of the system, can I connect my Polks x 4 speakers (DB 6501 Front and DB 501) and the Sub to the 4 Channel amp?
Or
Is it best that I have two amps in the car, (I already have the Sony 2 channel XM N 502 amp installed) and run the Pioneer Sub via the 2 channel as it is configuured now, and have the Polks running off the 4 Channel amp?
Thanks very much for you time.
Hello,
4ch;3ch;2ch
4 x 170 W
2 x 500 W
4 x 250 W
FREQUENCY RESPONSE
5–50 kHz
Or
6501 put on channel 1 and the 501s on channel 2. Bridge 3 and 4 for sub.
what if I wan this AMP with a P2 Rockford sub https://rockfordfosgate.com/products/details/p1000x5/ Had one shop quote me at 1100 for everything...
15
4K
6
155
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
607
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
341
Thirdmainroad
Thirdmainroad
India
disturbed471985
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
