2 Audiobahn 18's + 2 Amps = How should i set it up?
seriously i deal with people like this all the time, i assume you also walk into the stereo shop and tell the installer that his car sounds good, but then when he gives you advice you just laugh at him and tell him how sweet your old school stuff is? and that you dont wanna get the new stuff because the old stuff is way better back when audiobahn was in there "prime" as well as "RF" so take some advice or the flaming shall continue
who was it that has the quote in there sig that puts audiobahn on the same level as jessica simpson? we need a direct quote for that in this thread
Hey guys everyone back off. Before another person posts about audiobahn being ****......have you used it? If not then don't post. If so then give your opinion. I myself have not used audiobahn. My only experience is my friend had some bahns and they sounded pretty awful but it was a best buy special. I've never heard them in a decent box.
As for the amps.....no I would not use one amp per sub unless each sub had it's own box. even then you'll probably be running into problems.
As for the tinsel, If you know how to solder then just solder the tinsel back into it's original location. I'd probably leave a little extra slack since the reason it broke was because it was either too short or wasn't soldered properly.
And good luck. Not all audiobahns are bad.....just most of them. And when they are the cheapest product around, 90% of the people will say they **** without hearing them.
FYI.. These are not a Car shaking sub.. But these will give you some pretty nice bass in almost any vehicle that has nothing at all. Best placed...
158
417
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Donks
Donks
CO, Ohio
operationcougar
    May 18, 2024
    May 16, 2024
