(2) Kicker ZX750.1's
cdimic25
(2) Kicker Kz750.1s
•mono subwoofer amplifier
•375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
•variable low-pass filter (50-200 Hz at 24 dB per octave)
•variable bass boost (0-18 dB at 40 Hz)
•subsonic filter (12 dB at 25 Hz)
•Class D design
•CEA-2006 compliant
•speaker-level inputs
•preamp outputs
•fuse rating: 40A x 2
•4-gauge power and ground leads with 80-amp fuse recommended
•14-3/4"W x 2-3/8"H x 9-11/16"D
#1: Appearance- 10/10 Performance-10/10
#2: Appearance- 9/10 Performance-10/10 (small knick on bottom fin)
#1: $180+ shipping
#2: $175+ shipping
USPS comes as shown
#2
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
707
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
cdimic25
cdimic25
cdimic25
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
