2 of the KINETIK HC 1800 batteries - NEW IN BOX
  • 5
davidtemple
Caraudio Guru
i have 2 new KINETIK HC1800 BATTS FOR SALE IN BOX
NEW IN BOX
$175 EACH LOCAL / LOUISVILLE, KY AREA
WILL SHIP OUTSIDE LOCAL AREA AND YOU PAY ACTUAL SHIPPING COSTS
1800w
pecifications
Weight: 54lbs
Ah: 81
Dimensions: 10"x6.5"x8.2"
Suggested Retail: $419.99
Common Specifications
AGM Technology
Sealed Non-Spillable Design
Mount In Any Position
Ultra Low ESR
More Plates For Stronger Energy Density
Higher Voltage Under Load
Tightly Packed Cells
Superior Heat & Vibration Resistance
He does have a 18 iTrader feedback - so even though it is a rule that you include a pic of the item in the post, I would say that he can get a bit of trust that he does have the items.
Anyway - OP - pics of the items for sale please
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
409
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
9
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
davidtemple
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
