2 or 4 amps for 6 15s
  • 3
nuboot
so i decided to try out the hifonics brutus 15s. i know they arent the greatest subs but felt like i wanted to try them. so i got 6 of them now my issue is i have 4 powerbass 3k amps and i know that it is to much power for them but i could just keep the gains down. i am looking to put them in about 18 cubes maybe a little less but my question is would you use all 4 amps or just 2 of them
I'd just run 2 amps, unless you plan on upgrading at some point and will need all 4. If that's the case just run all 4 now and keep your gains way down, that way you won't have to rewire anything.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
355
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
512
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
nuboot
nuboot
lawton, ok
jrdnhsnbrg
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
