2 runs of zero?
  • 4
I have a 2001 Tahoe with one run of zero already, but I don't think another run of zero will fit through the hole. Do I need to make the hole bigger or drill a new hole?
I have to drill holes in my firewall to make my wire fit -.- ... so do it up, drill away!
Find a spot where it's clear on both sides to drill in the firewall. I use step bits with an impact driver. Just silicone them or seal them off and use grommets, don't let the wire jacket sit on that raw metal.
  • Locked
Here is another picture with today’s date and my username
9
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
3K
nice! yeah i don't know if that would be enough or not for the bigger setups... people here say it's enough for easily 10kw but i'll research...
14
I do not believe a different box will fix this and I generally distrust those """4 way""" coaxials. You could add some pieces of wood or even...
7
Bass911
Bass911
Dallas,TX
Buck
