2 SA 10s or 1 SA 12? New Here, Thanks!
kk99
Hey guys kinda new to the forum and I was wondering what setup I should do. I was thinking of running maybe 2 SA 10s in a ported box or 1 SA - 12 in a ported box. I currently have 2 Diamond D3 10's in a ported box running off of a planet audio 1250D. Any Suggestions? Box Builds? Etc? The room space in my trunk can only fit boxes 32" W , 15" Deep and 15" tall. Hope to get some good feedback, thanks guys.
first sundown system i heard local other than my own was two sa12s on a bb2400 and it slammed. i would go for the two 10s for double the motor force and more cone area. more power wont hurt either
Do the pair of 10s, don't forget going bigger doesn't mean louder.. Volume is all about motor force and applied power. (more motors more over all motor force, and more applied power with bigger amps //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif) Bigger cones mean more air movement, and the larger spider means better low end response most of the time. So!! pair of 10s all the way. The BB2400.1 would be a great match. It will smash
My brother still thinks size=db output.. That's why I bought him an SA8v2 on his birthday.. Hasn't installed it yet, but im sure he will enjoy 140db on music :p
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
kk99
kk99
Sacramento, CA
TaylorFade
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
