2 Subs 1 Vent ??
  • 4
Spddracer
Sounds Goooooood
1,337
Ohio
Is it ok to run 2 subs with the whole box sharing the same airspace and vent ??
Or should I run them in seperate chambers ?
Whats the advantages or disadvantages either way ??
I would like to run 2 with the same box and vent , Will I loose SQ by doing this or not ???? Thx for your replies !
This is what I'm wondering now also...if I build a ported box for 2 15's and have port on the left hand side...if you put a divider down the middle the port is useless as it becomes a sealed box...so I'm guessing that running the two subs in the same airspace with the same port is going to be fine.
- Steve
I personally run subs in a common chamber ported box quite frequently. I have'nt noticed any difference audibly. I usually build a slot port right down the middle. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by ramos I personally run subs in a common chamber ported box quite frequently. I have'nt noticed any difference audibly. I usually build a slot port right down the middle. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sounds like what I want to do ! Hey Ramos ??? Does it really matter what subs you are using when calc airspace and tuning the box ?? So long as the woofer size is the same
Yeah it does matter. Different parameters have different effects on enclosure size. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
spddracer, ur truck is an x-cab? u losing the back seat? if not, port ur box to one side or the other so it "bounces" the sound off the door. in theory, this should help u gain some db. my subs share same enclosure and the port "loads" up on the drivers side door. the only issue that i have found, and it could be a good thing, is when i have both drivers side doors closed, windows as well, and open the passanger front door.......BOOM! does she ever unload! not for sure of what i gain when it happens, but it's definitely noticable.
of course if ur losing the bckseat..............//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif my suggestion may not be the best option
Originally posted by mrray13 spddracer, ur truck is an x-cab? u losing the back seat? if not, port ur box to one side or the other so it "bounces" the sound off the door. in theory, this should help u gain some db. my subs share same enclosure and the port "loads" up on the drivers side door. the only issue that i have found, and it could be a good thing, is when i have both drivers side doors closed, windows as well, and open the passanger front door.......BOOM! does she ever unload! not for sure of what i gain when it happens, but it's definitely noticable.
I wish I had that much room !! Ya I have noticed that facing them (sealed) to the side really makes a big diff in spl , But when I port them doesnt seem to matter that much , I have everything in my truck out right now , Deadnend everything and am startiing my design for my box , Back seat is no more !!
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
192
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
442
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
4
596
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
860
Spddracer
Sounds Goooooood
Spddracer
Ohio
Spddracer
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
