2 subs 2 mono amps load?
  • 2
chiguy
CarAudio.com Newbie
I am wiring (2) 4ohm subs to (2) 2ohm stable monobloc amps. The 2 amps are the exact same but non-strapable. so i will be using rca-y spliters. My question is im using a online calculator were you put in how many channel your amp is the lowest load for amp and the sub ohm with how many subs and it gives you a wiring diagram .My question is should i put in 1 sub with a monobloc amp or should i put in 2 subs and 2 channel amp to get my wiring diagram. Also would the y-spliter effect the ohm load. would i be able to wire it with one wire into the positive of 1 amp and the negitive into the other amp so each amp would only have 1 speaker wire acting like a 2 channel amp. thanks
There's nothing to get creative about here. You're just connecting a 4 ohm sub to a mono amp -- twice.
Y-cables to split the signal will work fine -- although a lot of amps have outputs to make it easy to go from one amp to the next w/o y's.
I didn't mind the xbl² sound signature I just want more output and I don't think I can fit brahma 10s.
18
717
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
594
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
550
chiguy
CarAudio.com Newbie
chiguy
chicago
n2audio
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
