2000 budget
  • 5
Single 12...based on internal volume available. Sundown Audio x-12
Sundown or equivelant amp to power it....1500 or so.
small 4 ch amp....100x4 many brands to choose from.
CT Sounds comp set, or Polk Audio
Pioneer 80 prs
Knu wiring for amps, Royal Excelene for big 3 upgrade.
HO alt, aftermarket battery
Pioneer 80 prs
5cf Is perfect for a 15
Foh with that sundown ish //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif got nothing on my x2c's
Well he did say 4-5 cu ft. Which tells me he's not sure so I mentioned a 12. Takes up less space than a 15. Once he factors in the port, bracing, and speaker displacement, it'll be kinda tight for a 15.
I'm just playing. Trying to get out of these b2's for some 3" coils lol
Yeah I was just thinking I don't really want to take up the entire trunk, so a 12 or 2 10s would be good. Do I really need a HO alt for 1500 watts?
Old school kenwood 5v HU $150 or new HU for like $300
2 12" cab woofers. $400
Build a box $100
Wire and accessories $200
Cab 1600.1 sub amp $200
6.5comp set $150
4ch amp $150
AGM batt under hood $130
AGM g31 for in the trunk $200
That would get u banging
If I were in your place I'd go...
HU - Pioneer DEH-X6900BT or Pioneer MVH-X580BS (no CDs) - $100ish
Front Amp - Zapco ST-4X P - $220ish
Tweet - Alpine SPX Pro Imitations - $30ish for the set
Mid - SB Acoustic 6.5 - $120ish for the pair
Ground and power wire - 20ft Excelene 1/0 AWG - $40ish
250 Amp Breaker - Stinger 250 Amp - $30ish
RCAs - Mediabridge 25' - $45ish for 3 sets
Distribution Block - KnuKonceptz KNF-60 - $40ish
Speaker Wire - KnuKonceptz Kord 16 Gauge 100' - $30ish
That's $655ish. Figure another $100ish for odds and ends like HU install kits and smaller power ground wire for amps to distro, etc. That leaves $1245 for your sub stage.
Some great recs for sub and sub amps have already been mentioned so I'll defer to those guys.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
3K
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
5
UGHH
UGHH
Sacramento, CA
k5james
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
