2000 Durango
  • 5
Nice truck, I drive the same thing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What motor do you have?
Also, how did you do those door pods? I would be interested in doing the same exact thing if its a simple task.
Its got the 4.7, For the door pods i just cut out the factory grills and mounted the speakers on the door panel, only took about 20 minutes
How do they sound? I could'nt imagine any midbass would be there, considering it's not sealed off from the door (sheet metal) in any way. Do you have pics from behind?
they sound ok,the midbass sounds better than i thought it would.Im planning on sealing it off soon so ill post some pics of that also
Most def do, i would be interested in seeing how to seal that part off, there is TONS of room in there!
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
autosportsunltd
autosportsunltd
Clarksburg WV
alxmlr789
    May 18, 2024
    May 16, 2024
