2001 Aurora Radio Static excess interference
  • 2
shedden
When playing AM stations I get lots of static making it unable to listen or even tolerate the radio being on. Worse when I am under a high tension electric wire (expected) or driving along a road with electric wires. Translated: most of the time. Occured even when new. Dealer has not helped. When I use my turn signal the radio static will cease. Eventually returns. Speed control(on a column mounted level with a push in switch) switch can be turned on and off with obvious static effect sound heard over the radio. FM is okay. Only AM radio is affected. Less problem if station is close as in 10 miles.
Check the grounds for the radio, and the turn signals...since you know what solves the problem, work backwards from there. I'm willing to bet you have an intermittent ground somewhere.
The noise under power lines is expected; nothing you can do about that.
appriecate it man! I was so busy thinking about it that I didn't even think I could look it up with a multimeter.
5
You should use an adapter. You might gain some insight on a Town Car forum as well. https://www.installer.com/cars/by_car.php?carid=3402
shedden
shedden
Louisville, Ohio
JimJ
