2002 Accord - Power Steering Pump??
  • 3
Zxcvtypo
2002 Accord EX 4cyl 5-speed
This is the noise my car is regularly making when the steering wheel is turned. Sometimes it doesn't do it at all, sometimes it's a lot worse..I can't figure out what's causing it to come on and off. It also changes a little with rpm's as I'm accelerating in 1st-2nd, leading me to believe it could be the alt or belt?
Is it the power steering pump going bad? Alternator? Loose belt? I wanna try to get an idea of what it is before I take it in somewhere..I've read a lot of different things online.
have you recently gotten your alternator replaced? If so, the alternator might need to be adjusted slightly because the belt is to loose on it. It could be your power steering pump, but it can also be because of your belt. I doubt its your steering rack, if it is, than thats going to put a hole in your pocket.
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
I have a 2001 Nissan Sentra GXE and I've never found one. The loc is the next best option
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
6
897
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
791
Zxcvtypo
Zxcvtypo
Frederick, MD
audioatg
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
