Work has been slow going. Its too hot for me during the day, so Im only working on it in the mornings and evenings. Ive got a sheet of dynamat pressed in and filled a bunch of cavities with the denim insulation over the rear wheel wells and in the cavities under the seats.
This is the rear seatbelt cavity, leave room for the seatbelt roll, denim can be stuffed all the up the C pillar and over the wheel well from here.
This is the left side cavity behind the wheel well, denim can be pushed in here to finish filling over the wheel well and behind it. I made sure to push it up to the window and down to the tail light. There are a few bags filled with denim insulation from the factory, I tore them open and used the denim to pack the cavities with the home depot stuff. There is another cavity next to the hatch that can finish filling behind the tail lights, but I didnt take a picture before I sealed it with dynamat. Once the cavities are filled I sealed them all with dynamat, you could use roof flashing and screw it down, then dynamat, but I didnt want to expose the metal to possible rusting. If youre going to screw, ideally youd use threaded rivets and clear coat the drill holes.
These are the support channels running across the floor under the seats. I used a screw driver to really jam them in there.
Heres a view of the front of the floor so far, you can see all the leftovers after 6 rolls of denim. I thought 6 rolls was too much, but it goes fast. For the B pillars Im going to reuse the denim insulation that I ripped off the carpet. This will be replaced by my denim backed thermal barrier and MLV. If youre going to do this you have to rip off the old backing or everything else wont fit.
There is the same denim stuff behind most of the plastic panels that Ive removed. Im going to rip all this off and put dynamat there too, but only iff I have any left after I do the floors and doors. If I run out Im going to use a home depot replacement that is thinner, but people have used it with success in place of dynamat. If I didnt already have the first set od dynamat and done the rear hatch area I wouldve used that product for the entire car for cost purposes. However I want my E to be even so I order another set of dynamat.
Tonight after the boys are in bed Im going to roll on another large sheet of dynamat that should finish off the floor. The new dynamat that I ordered is cut in smaller sheets for ease of shipping. These will be used for the doors and whatever this last large sheet doesnt get to. Ill do the front doors first and then rear doors in case I run out.
Ive decided to not put any speakers in the rear doors so I can eventually run my front mids and tweets active off the 5 channel amp I have. Right now Ill be installing my Focal PS165 component set with the included crossovers, but Ill run extra speaker wire to connect the tweeters separate later on. The crossovers will live near the amp so I can just move the tweeter wires from the crossovers to the amp when I go active later. While I have the door skins off in the back I will run 2 sets of speaker wires to each door in case I change my mind about those. I did buy a set of Hertz HCX165 coaxials for the rears and they should be pretty nice, but I rarely have anyone in the back seat and I carry stuff like a truck back there with the seats folded down a lot anyway. What do you guys think? Does the rear fill reall matter? Once I go active Ill either have to add an amp or get rid of the rears anyway. The easiest way to do that would be to get a small amp for the tweets and run the doors off the 5 channel Alpine PDX-V9. The way Id go active is with a Pioneer DEH-80PRS all the audio forums can say enough good things about this HU and I dont think Im ready to get a dedicated DSP. Also the 80PRS has an auto EQ and time delay feature that uses an included microphone to tune your system for you, small adjustments can be made afterwards or you can fully program everything yourself. You just place the mic where your head would be and run the program. These HU run for $250 on
amazon so it wont break the bank, I just need to save a little or maybe Santa will get me one?
