2002 MDX acura
  • 3
SeattleSEA
I have a 2002 MDX acura.
I have a factory Installed DVD player. This is not connected to the factory sterio. The dvd player is located under it.
My question is if I change my factory sterio to a double din will I loose my sound from my DVD player? Because the option for sound on the DVD player would come through settings on the factory sterio. Also would I even still be able to play DVDs?
Can someone who changed their 2002mdx tell me what happend with their DVD player if it still worked or if not what did you to in able it to be able to work?
Please and thank you!!View attachment 26552600View attachment 26552600View attachment 26552600
I would think not....so long as the speaker wiring harness is connected to the double din. Find yourself a install kit to from Metro.
You will need to find a replacement radio that will accept audio output from the dvd player
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
I have a 2001 Nissan Sentra GXE and I've never found one. The loc is the next best option
Are you planning on upgrading the alternator and add extra batteries?
777
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
SeattleSEA
SeattleSEA
Washington
supra1987
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
