2004 audi a4 build log
  • 1
Falcons
that **** i dont like
What's up guys. Gonna be periodically posting my build as I get it done.
Material is as follows:
-15" 2008 Memphis mojo d2 with split audio soft parts
-dd m3b
-pioneer deh 80prs
-phd FB 6.1 component speakers
- precision power bk 800.4
-220amp singer alt
-limitless 500farad 16.2v supercapacitor
-3/0 excelene welding wire
Just got the amp rack dome today for the most part. All that's missing is some metal L brackets to strengthen the shelves.
22286
22287
22288
22289
22290
22291
22292
22293
Did my big three today. Drilled holes through the firewall and protected the wire with grommets so I could retain my factory deck over the battery. Had to remove the coolant reservoir to get my fuse attached to the frame. That wasnt fun 😂😂
22316
22317
22318
22319
22320
22321
22322
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
Falcons
Falcons
Albion, New York, United States
Falcons
