2004 Dodge Ram 1500 Install, HELP!!
  • 2
Logik287
Hey everyone, my first post on the site. I'm putting a subwoofer into my 2004 dodge ram 1500 quad cab, and I'm having a hard time putting together whats gonna work/sound good.
Currently running a Kenwood head unit with Alpine type-s speakers in front and rear. Time to add a subwoofer to the setup.
My original plan was to use a ALPINE SWR-1042D 10" with a Alpine MRP-M500 amp. Into a prebuilt enclosure from ebay, pushin 500 Watts RMS i think it would be plenty for what i want. I only want 1 subwoofer as i need a little storage space under the other seat. Im having a few worries:
1. Will the box sound good at all, heard mixed reviews on those boxes (the airspace meets reqs for the sub)
2. Will i even be able to fit the subwoofer into the box? Mounting depth in the box claims 7' and my sub is 5 7/8' but i'm a little skeptical
Has anyone done a similar setup in a dodge ram? Or have any reccomendations for other possible setups? I could really use some outside input on the situation. Thanks!
Use 3/4 mdf or birch plywood using 1x1 for corner bracing some of the guys on here are good with box design they may have ideas for a box that would fit what kind of dimensions do you have to work with under the seats
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
Logik287
Logik287
Calgary, AB
Robert 2001
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
