2007 corvette gmos014
  • 3
Varinabassing
Richmond,Va
Ok so I am installing a few amps and speakers in my vette. I have installed the gmos 014 to give me a constant power. But I am not getting a ignition power for some reason. If I connect the ignition wire to the constant I get the deck to cut on but can't seem to find the switch ignition
Also when I turn the gain up on the amp I get a crazy screeching noise through the speakers. Thought maybe a ground will change that tomorrow
Any thoughts on the gmos 014 ? Told me in the instructions to cut a green/orange wire and pink wire. Anyone installed one of these in a vette wanna give some input
try grounding the adapter to the metal floor (sand away paint).
also, double check all connections. did you solder connections? crimp? how?
the GMOS adapter gets a digital signal from the car to engage the turn-on output on the GMOS (ignition).
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
The harnesses showing up for your vehicle show one or two adapter plugs. If your car has a separate CD player, then I assume that is what the 3rd...
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
6
896
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
9
152
Varinabassing
Varinabassing
Richmond,Va
Varinabassing
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
