2008 Accord Coupe
Trunk Liner -
In my process of deadening the trunk, I decided to add some closed cell foam (Ensolite) to the back of the trunk liner. I used some spray adhesive and did it all in one piece. I tried my best to match all of the contours of the trunk liner, and think it came out pretty good.
Awesome job mang! Not a big fan of the amps, but as long as it does that trick for you, then that is all that matters. Love the attention to detail of the entire install. I may pick up a set of those RSD's if I don't like my Alpine SPX'S. They are a nice set, but very mellow IMO.
I will have pics up next week of my install, well mostly my sound deadening install as I had my system in there and had to take it out and reinstall it. Deadening *****, as my hands look like I got in a fight with Edward Siccsorhands.
Good luck on the rest and will deffinetly check back.
Door Trim Panel Deadening -
Even with the stock speakers, when played at anything past a medium volume level, I noticed that the door trim panel and armrest area would vibrate like crazy. I decided to do some deadening action on it. I built up a lot of layers around the speaker grill, just took whatever scrap I had left, and piled it on.
those 'quick connects' for the speaker wire... did you make those or are they sold like that somewhat? very slick...
any pics of this badboy in the trunk?
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
And it works great with android phones, you can connect, and what can you say about android radio tape recorders are now leaders in functionality...
ie just used a new adapter because adapters ignition wiring wouldn't keep constant, works fine now and stopped sending sensors off, never had the...
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
967
katodevin
katodevin
San Jose, CA
RoachForLife
