2011 Fiesta (47k miles) Sync 1 to Sync 3
  • 1
AxisPaxDeo
CarAudio.com Newbie
Hi crew! I’m reaching out for some help. I have a 2011 Fiesta SES and have all the parts needed for a conversion to Sync 3 except the harness. I‘ve looked for pin out guides and found a few but some have seemingly conflicting info. Can anyone help?
Here are some of the resources I’m using to make a harness:
  1. This great guide on mapping a harness and/or swapping pins: Guide: Upgrade Sync 1 to Sync 2/3
  2. This info on the Sync 1 pins: Ford (2013-2016) Sync 1/2 APIM module pinout diagram @ pinoutguide.com
  3. This general pin out map with info about the fdcim pins: NAVIGATION – Ford Fiesta SES 2011 – SYSTEM WIRING DIAGRAMS – Wiring diagrams for cars
  4. And this Sync 3 pin out guide, but it has two pin diagrams. Which version does the Fiesta 6.5” Sync 3 (2016) have? The one with or without Sony and DSP? Ford (2015-2020) Sync 3 APIM module pinout diagram @ pinoutguide.com
I’m also curious what are the minimum pins I must connect to check if the Sync 3 module/screen still works. I would think the 12v bat, ground, and some of the cans (maybe ms cans from fdcim port to the proper Sync 3 pins??) to communicate and hear from the car that it should turn on.
Thanks, in advance, for any help you can provide!
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
232
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
HUGE thanks to everyone who contributed in here to helping me determine my amp was the issue. You guys were great. I now own a multimeter which...
53
5K
Ok. I think I get it. There's really not much to be gained between charging them at say 60% and 100%. At least not on a daily system. Please...
13
AxisPaxDeo
CarAudio.com Newbie
AxisPaxDeo
Crystal Lake, IL
AxisPaxDeo
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
