2012 Honda Civic Remote Start OEM
  • 4
1. No it shouldn't be that high. 2. I havent actually heard of an OEM Honda alarm. Most of the time dealers pay a company to do it (which is usually not a good installer or install techniques). 3. aftermarket is ABSOLUTELY cheaper. 4. don't let the dealer state that it will void your warranty, that's completely false - read magnuson-moss act.
A customer of mine was quoted the same at her honda dealer. The honda remote start is stupid expensive when it doesn't even have the range as an aftermarket one. I would recommend saving some money and going aftermarket.
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
4
674
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
JamesBondo
JamesBondo
Atlanta, GA
bigaudiofanatic
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
